Jim W in Tampa said:
Anyone able to remove a blank and install the light could handle taking down the fan.
Uh...not to...er...uh...that's a pretty broad statement, Jim. I'm pretty sure plenty of electricians on this forum have recieved offers to hang ceiling fans that husband started hanging or didn't feel comfortable hanging. That's practically the same thing.
That said, the current requirement would require someone with some electrical skill to hang a luminaire down the road, if a blank is installed in the first place, so it's not germaine to the discussion, I don't think.
pjg said:
But the definition of lighting outlet states that is is "intended for a fixture..., "not "shall have a fixture installed"
If you install a ceiling fan box, and then install a ceiling fan, then how is the inspector to know that you intend to remove the fan for a luminaire someday? Can't you see the stretch?
pjg said:
No where does it say it has to be used for a fixture only that it is installed and switched and available for a fixture even with the fan installed it is still in the ceiling and could be used for a light fixture(Just remove the fan).
Look at this one more different way. Let's take it for granted that the inspector in this scenario can only inspect to the NEC, and can't enforce any other document. Okay?
You install a smoke detector in the room, and a smoke detector only. No switch, no round box in the center of the room, and no switched receptacle.
The inspector walks in and cites 210.70(A)(1). You say, "No, that single gang in the ceiling is my lighting outlet, and the circuit breaker in the panel on that wall there, marked SWD, is my switch." Under protest, the inspector signs off.
Come trim time, you install a smoke detector in the ceiling, and the inspector once again cites 210.70(A)(1). "You never intended to install a luminaire there, so it is an outlet for a smoke detector, not a lighting outlet."
You retort, "That can come down at any point they'd like to install a luminaire or a lampholder there. I'm just installing a smoke to cover the hole in the meantime.
It will always be available for use for a luminaire."
Do you have a leg to stand on?
How can we demonstrate our intentions? We buy a round box, and wire it to a switch.
The code doesn't ask for a round box and a switch - if it did, this would be open and shut. The code asks for intentions, which the history of mankind demonstrates, can and will be misinterpreted.
