kwired
Electron manager
- NE Nebraska
- EC
I personally believe that the rods are needed but you can use the rods that are at the pole. The trailers I see around here, the pole is located within 5 feet of the home. This would make using those rods easier. Anyone see a problem with that.
Most of the time the service or disconnect is 5 feet or so from the home - it does seem pointless to require a separate electrode(s) when it is that close.
Think about two separate buildings that are right next to each other. They each need a separate service or feeder and separate grounding electrode systems. Now take same two buildings and build an enclosed walkway between them or do something that connects them and allows you to call them one building - now they can only have one service, understandable, but a grounding electrode system is no longer required on the second building even though electrically nothing may have changed. The two panels could be hundreds of feet apart if the buildings are large enough, yet the service or feeder disconnect for a mobile home will be a maximum of 30 feet from the mobile home.
Just food for thought.
