Very interesting thread.
I would like to find out if the problem with the stuck contacts are limited to one manufacturer.
The next thing I would do would be to try to find out if the failed units were feeding other receptacles.
Of course, taking them apart would be in order.
I have now, officially, changed the way I test GFCI receptacles. After hitting the test button, I will check for power to ground. That won't be easy if there is no ground, but I will figure something out. I would like to get my hands on a failed unit that I could used on a two wire system to figure out the easiest way to test them.
