No contradiction, old chap.As you say ''used these for limiting di/dt in power electronics'', it seems to imply ''i'' of higher frequency as the slope of ''i '' i.e di/dt increases with increase in frequency of ''i''.
What a self contradiction!
They often are in substations to limit inrush in capacitor banks and reduce fault currents on feeders:
http://www.energy.siemens.com/br/po...ge-products/coil-products/coil-products-l.jpg
http://www.coilinnovation.com/typo3temp/pics/4efc93a1ac.jpg
http://www.huguanggroup.com/product_images/big/20140519040010434220.jpg
Introduction of a series capacitor in the lamp circuit with inductance will reduce the overall impedance presented to the power supply and if such an act is not part of the original design, it would likely increase the current through the lamp above its design value with consequent reduction in its rated life due to nature of tungsten filaments at the lamp ends.
Wow! Just wow!
It was the sheer scale that awed me.What? :? Those are air chock reactors, right?
slope does increase with frequency
assume 2 signals, unit magnitude 1A
f1 = 1 Hz
f2 = 10 Hz
start at zero crossing
1/4 cycle positive slope, then 1/2 cycle negative, the 1/4 positive, repeat
let's focus on the first 1/4 positive
time duration for 1 cycle: 1/1 = 1 sec, 1/4 cycle = 0.25 or 1/4
f1 di/dt ~ delta I / delta t = 1/(1/4) = 4 A/sec
time duration for 1 cycle: 1/10 = 0.1 sec, 1/4 cycle = 0.025 or 1/40
f2 di/dt ~ delta I / delta t = 1/(1/40) = 40 A/sec
much 'steeper'
another way to look at this
Xl = j (2 Pi f) L
as f increases, so does X and it 'chokes' or suppresses the higher frequencies
it can be said as 'slope' (di/dt) increases so does impedance
With all the respect merited, I think you totally missed the point.
Rate of change current or di/dt can be detrimental to the operation of power semiconductors. Or even kill them.
For example, this can happen in variable speed DC drives where SCRs are used to convert fixed voltage, fixed frequency to variable voltage DC.
The SCR is essentially a solid state switch. Turn it on at whichever part of the cycle is required and the current will rise at whatever rate the external circuitry allows. Without line reactors, the di/dt could exceed the capability of the SCR which is typically in the order of several hundred Amps per microsecond for converter grade devices.
It's a transient, not a steady value which is what you presented.
Oh :lol: Trust me, thats nothing. When I think of air chocks thats what I imagine. But if you really want to say wow, check out 7:15 onward. 8:45 gives you some perspective :thumbsup::
https://www.youtube.com/watch?v=z7pIOPS_ifI
was not talking about interaction with a IGBT's etc.
only the physics of the choke
di/dt is not steady state
I've had a ton of schooling and experience on various types of convertors
built them up from raw components
for example
ECE 2250 : Power Electronics Circuits & Applications
also a good exposure in FACTS/HVDC courses
the current course is on PV and wind generation, convertors are essential
been working with SS convertors since the mid 80's
But you still missed the fundamental point.was not talking about interaction with a IGBT's etc.
for example
Excellent. Thank you for that. Put me down as impressed.
chokes are increasingly used for active Q compensation/pf correction
using thyristor controllers
we have 4 major players in the area
ABB
Alstom
Westinghouse
Mitsubishi
their FACTS/HVAC divisions are local
I think the inductor along with capacitor is used for ripple control in the output. The ripple current has a frequency and inductor is there to limit its di/dt.With all the respect merited, I think you totally missed the point.Rate of change current or di/dt can be detrimental to the operation of power semiconductors. Or even kill them.For example, this can happen in variable speed DC drives where SCRs are used to convert fixed voltage, fixed frequency to variable voltage DC.The SCR is essentially a solid state switch. Turn it on at whichever part of the cycle is required and the current will rise at whatever rate the external circuitry allows. Without line reactors, the di/dt could exceed the capability of the SCR which is typically in the order of several hundred Amps per microsecond for converter grade devices.It's a transient, not a steady value which is what you presented.
Yours and mine too!Welcome and I will. :lol: Yes, its a tad large by my standards.
No problem.
Have fun.Apparently you did
it happens
These provide smoothing and absorption of harmonics created by switching valves?
