JohnE
- Milford, MA
- Electrical Contractor, Inspector
Flex said:My quote ability is not NEC compliant
You're quoting ability is driving me to another forum.
Flex said:Namecalling is not necessary.
Flex said:somewhat, we only use compression fittings for emt, no set screw allowed on our jobs
peter d said:I stand by what I said. It is foolish to apply the same level of quality, workmanship, and materials to each and every job. And those who practice that are fools.
roger said:I'm not talking about compression verses set screw EMT fittings, right now there is very little price difference in steel compression verse steel set screw fittings.
I'm talking about the difference in almost a $1.00 a shot for a lot of pieces.
Roger
Flex said:If its spec'd then yea of course he would
roger said:No, no, no, that's not the issue at hand.
If it's specked we all get to add it into our quote, this is not the same thing as voluntarily doing it at added expense to ourselves.
Tell your boss that to really be respected by us, he will have go over and beyond the bare minimum and out of the goodness of his heart and at no additional cost to the customer, use these receptacles on all jobs from here on. :grin:
Roger
Flex said:Then a fool must be a high quality electrician not a shoemaker who cant feed his family unless he cuts corners.
peter d said:I believe it was a wise man named Marc Shunk who once stated that there are those who are constantly exploring the limits [of installation practices] in the interest of maximizing their bottom lines.
I happen to believe in that principle myself, and that includes doing code minimum work when necessary, and even work that your would say looks "crappy." I have no shame in that whatsoever.
Furthermore, it's a shame that you have not been able to see the other side of this argument.
Flex said:Just did a 96 room hotel with all those outlets. You should see the GFI's.
j_erickson said:Were they spec'd? If your boss voluntarily included them in the job and they were not in the spec's then he is an idiot. Period. And if that's the case I would be BS if I were you because that would be a couple grand more a week he could be sending your way.
Flex said:Dude im sellin a bridge in Brooklyn if your interested.
iwire said:dnem said:Do you run your raceways between terminations "as the crow flys" ? . Do you install diagonally to save a few feet of wire ? . NEC allows you to do that. .
Sure I do, if that make sense for the job and the customer.
I often work in stores that are very large if the electric room is in one corner and the load is in the other it makes no sense electrically to add to the circuit length for no other reason then to keep the circuit perpendicular to the building. To do so is wasteful and foolish.
peter d said:I suspect that if you even own or run a business your perspective on this issue will change. Until then, you are just patting yourself on the back.
roger said:dnem said:Now you answer a few of my questions
Do you run raceways or cables diagonally [high to low, low to high] in stud walls ?
Do you consider diagonal runs to be NEC compliant ?
Do you consider diagonal runs to be safe ?
Do you consider diagonal runs to be professional ?
I know you weren't asking me but I will answer, Yes to all of the above, and you couldn't red tag an installation for any of the above so what's the point of the questions?
Roger
dnem said:. . . .
Bob, Peter, + Roger
You guys continue just as you are. . Do whatever you wish. . I'm going to continue to be "wasteful and foolish". . I never chased the bottom of the barrel jobs when I was a contractor and I never will. . If I go back into contracting, I'll bid jobs that are looking for "wasteful and foolish" installation. . If I have to get work by leading with a basement price instead of selling quality, then there's no reason to be in business.
I inspect the bottom feeders work everyday. . They literally run thru their jobsites chasing a bid that barely pays their bills. . They are some of the most unhappy electricians I have ever met. . Some of their employees make more than they do. . And their employees are among the worst paid.
brantmacga said:that is all speculative information. you have no clue what they're actually doing, so stop pretending you do.
brantmacga said:i could say based on the above information that you most likely went out of business because you were a poor businessman and refused to do work that you felt was beneath you; turns out nothing was or is. but that's all speculation.
brantmacga said:Take a poll of customers and you'll find out the majority care not how pretty you installed the work, but only care that it works and is affordable. not selling the customer what they can afford because you think its not worth doing is witless, and the mark of a true amateur.
