perry vogler
- Wildwood Florida
IF you are going to do somthing like that in the furture, I would leave the inspector a note. Sometimes the inspectors can help you avoid a lot of costly work with the forsite they have.
What you did is not a code violation until you installed this on a breaker larger than a 15, If you perminatly identify the wire in the panel for the breaker size this may have helped. He does need to know this, and I will tell you why.
This is not a code violation, its a red flag warning. Whenever you go way off the beaten path you raise a red flag, like too many staples in romex, or too many straps holding up MC cable. Yes it is ok to install as many straps as you want and not violate the code but it tell the inspector that you may not no the code on spacing, that makes him look closley at everything to find out what else you didn't know about the code. Be carefull, know your codes. If you are unfarmillair with the product, look for the do's and dont's in the code book before you start and refresh your memeory. Don't throw off any red flags for the inspector. And lastly as a Contractor, It is ok fine for a second set of eyes to look at your work and point out anything you may have missed that may cause a recall or even a fire, yes it does hurt your pride a little but it is much better than callig your Lawyer or insurance company. I would explain what you were doing with the #12 wire, perminatly identify the wire to go into a 15 amp breaker, thank the inspector for watching out for a possible house fire and quit mixing wire sizes.
PS I couldn't tell you all of this if I haven't done it myself, Perry Vogler
