mivey said:He would probably put them in the jugular of the one who asked him to do that.![]()
You got me laughing again. Me?? Calm, collected me - of course not (giggle, snork)
carl
Sure there is. As one measures around the loop, you put the the red lead in front of the black lead - all the way around the loop until the red lead is back to the start. Kirchof (sp?) wasn't it?rattus said:Yes, they do. ... There is no other place to put the black lead. ...
Because the way one wires them is not necessarily the way one would analyze them.rattus said:Yes, they do. Both have neutrals, so why not measure the voltages in the same manner?...
I think we all knew that.:grin:rattus said:... I don't see anything crippling about it. ...
Thank yourattus said:... It is just steady state analysis, and as I said you can analyze any way you wish. ...
Mivey's answer was pretty good. (Mivey - Bad Dog)rattus said:... Just think of a black box with 3 test jacks--red, black, and red. Now you are asked to describe the AC voltages on the red jacks relative to the black one. Where would you put your test leads?
crossman said:Here ya go Rattus!
Either way of measuring is correct. In the first photo, the L1 to N voltage and the L2 to N voltage ARE indeed 180 out of phase. You cannot say that using the neutral as the reference is a "trick" to make the voltages out of phase. There is more than one way to look at any problem in physics, depending on the reference frame one chooses.
Don Randall said:I'm wondering what reference frame you chose to use on the second, in phase, trace.
crossman said:What if I make L1 the reference and put the black lead there for both channels? Then I take the red lead of channel 1 to N and the red lead of channel 2 to L2? I get a 120v RMS sine wave in phase with a 240v RMS sine wave. No big deal. The math still works if you do it correctly.
Now, in that last example, what about the "ADD" function on Don's o-scope? It now adds up to 360 RMS?
If the predictions made from the math model precipitated from the chosen reference agrees with empherical data - then the reference/model is valid.crossman said:What would be the criteria for determining whether a chosen reference frame is valid or invalid?
But yet those people are likely to say L1 (A) and L2 (B) are 120? out of phase discussing an ungrounded delta secondary w/o any center taps. In this case, you cannot even prove a 120? relationship by entering L3 (C) into the picture with basic measurements. One has to resort to a math/physics model to prove it, because the system neutral point is a virtual one, without any real world connection point.Don Randall said:...some people flatly state that L1 and L2 are 180? out of phase with each other without any qualifiers such as "using the center tap as a reference point".
coulter said:If the predictions made from the math model precipitated from the chosen reference agrees with empherical data - then the reference/model is valid.
I don't know - sort of depends on what you expect from the model.crossman said:...So how many and which of the following reference frames would be valid? ...
crossman - good buddy, we have discussed this. Single phase is trivial. Nobody bothers to do any single phase analysis. If the expectation to to get the meter to read as you expect, then any will work.crossman said:...Do any of these fail to represent the empirical data if we are stringent and proper in the use of the math?
Don Randall said:The center-tap does not change the relationship between L1 and L2.
Don Randall said:I was going to say that the scope results prove that the setup is invalid.
I don't know about that. I would say, for instance, in the 2 lead output of a typical transformer, (bell, heater control, etc.), that every part of the that output circuit is in phase with every other part. (Of course I would say the same about a center-tapped transformer, with which you seem to disagree.) I'll draw you a simple diagram later to illustrate my thoughts. I believe phase is determined by the timing of the ac pulses, and the direction of the current flow for those pulses, (controlled by the voltage). If you wound half of the secondary opposite to the other half, then I would consider the two conductors, L1 and L2 to be out of phase with each other. If you put in a center-tap, it wouldn't change the phase relationship of those two conductors. Doncrossman said:L1 to L2 is a single voltage measurement and cannot be said to be in phase or out of phase.
It does on mine.crossman said:Now, in that last example, what about the "ADD" function on Don's o-scope? It now adds up to 360 RMS?
No. It indicates you have the wrong settings on your oscope, unless you really intend to add the two signals.Don Randall said:To me, it indicates that you have chosen another invalid reference point to compare the phases of two identical coils,(electrically the same as 2 coils.)
thatthatthatcoulter said:If the predictions made from the math model precipitated from the chosen reference agrees with empherical data - then the reference/model is valid.
Say that three time real fast.
carl
crossman said:Forgive my ignorance of typical o-scopes, but I have a question: with a two channel scope, don't the two channels usually have a common lead? There is a one lead that is used for both channels, then a CH1 lead and a CH2 lead? And in some o-scopes, the common lead is bonded to the o-scope chassis?
My LabVolt O-scope has 3 isolated channels, in other words, each channel has its own two leads and no interconnections between them. This isn't typical of scopes, is it?
Well, I think to use the back to back arrows to depict 1ph 120/240, in an educational setting, is needlessly limiting.crossman said:Sorry Carl... I guess I still have it in my head that some people in this thread are saying that using the neutral as the reference is wrong.
Wait... some people ARE saying that!!
mivey said:It does on mine.
A flat line.Don Randall said:Hey Mivey, What did your scope show when you used the add function on the two 180? out of phase traces? Don
