- Windsor, CO NEC: 2023
- Hospital Master Electrician
Re: Switched Din. Rm. Outlet?
Bless your heart, here's what you're missing, Mike.
A switched receptacle shall be permitted in lieu of a lighting outlet.
If you install a switched receptacle in place of a lighting outlet, the lighting outlet doesn't exist anymore. It been replaced by a switched receptacle. There is no lighting outlet. The lighting outlet is gone. Now the room has a switched receptacle. All the receptacles in the room are on a SA circuit, as 210.52(B) requires. Since the switched receptacle is on the SA circuit as required, I don't need to use exceptions to justify it's presence in the dining room. It's supposed to be there.
There is no lighting outlet. Gone.
[ March 27, 2005, 11:07 AM: Message edited by: georgestolz ]
