allenwayne
Re: Switched Din. Rm. Outlet?
.To me it is code compliant both on a 20 amp circuit,there is a switched outlet in both rooms
So did we comply with min. requirements in both rooms
Want to nit pick this subject go ahead but to me it is code compliant minimum standards have been met,all is good
I have done this same senario,in which there were 2 rooms side by side,origanlly a living room on the floor plans but h.o`r wanted to swap the lay outOriginally posted by peter d:
Survey: (Curiosity factor here) How many of you have actually had to install a switched dining room outlet?
If so, did you lie awake at night, tossing and turning, while thinking about the NEC ramifications of doing such an installation?
