Krim
- Maryland's Eastern Shore
76nemo said:... Do you twist your wires together, or allow the wirenut to do so? ...
I twist them together either by hand or when necessary with my linesman pliers,than screw on the wirenut. I sometimes wrap tape around the wire & wirenut too where vibration may cause them to come loose. As for waterproofing the connections,if the joint is large enough I'll apply mastic and tape, otherwise I use those wirenuts with the silicone seal by Ideal.
Carl
