mdshunk
- Right here.
Somebody installed classified replacement breakers in the panel, so the Square D warranty rejection feature rebelled by causing wacky voltages at the bus stabs.
What problem?:-?electricalperson said:im getting sleepy...whats the answer to the problem![]()
mdshunk said:Somebody installed classified replacement breakers in the panel, so the Square D warranty rejection feature rebelled by causing wacky voltages at the bus stabs.
Siemens makes or made a QO classified replacement. They had green handles.480sparky said:All QOs, and I think this would have been well before the counterfeits were discovered.
mdshunk said:Siemens makes or made a QO classified replacement. They had green handles.
mdshunk said:Generator stuck on.
Yep! The last one I installed had a factory defect in the head! Warped vavle guide(s)peter d said:Probably a Genercrap.
mdshunk said:Somebody replace the panel cover with a moss-covered three-handled family gredunza?
Probably not. Therein lies the fundamental problem.ultramegabob said:are those listed?
mdshunk said:Probably not. Therein lies the fundamental problem.
480sparky said:Can't it just create it's own listing?![]()
Probably, but it would need a Mortimer Ichabod marker. I don't think Bill's sending them out anymore.480sparky said:Can't it just create it's own listing?![]()
stickboy1375 said:Cant you just post your answer? :roll:
Ebow is on the right track.....Ebow said:it's obvious that the highs and lows add up to nominal but what about the 240 high on one leg?
Gene
okay 220v approx on one leg.
