Jim W in Tampa
- Tampa Florida
Jim, you have been telling us all the receptacles in the laundry area must be supplied by the 'laundry area' circuit and that I can not add another one.
So in that case I cannot install an electric dryer receptacle.
Or lets say I had a gas dryer that draws 11 amps at 120 volts and I have a washer that draws 11 amps, you are saying I could not install a second circuit into that area even though the load might require it.
I never said you cant have 2 circuits and if you do they are laundry receptacle circuits and can have no other outlets.
note it says 20 amp circuits and no mention of a 30 amp or any other.
Now if your trying to win this you could ask if you can have a 120 volt 15 amp circuit
I did not write this mess NEC did. And it leaves a lot of gray in it.
This is the result of trying to keep repairing an 80 year old code with patches over patches
