If it was rated for the application it wouldn't run overtemp at all.why do you misrepresent it?
he said 'usually', but not in this case, in this case output was clamped at 840 kva
impossible
impossible
it did not run over temp, at all
According to the OP, it did.
"usually it just runs over temp."
Simple and direct. I don't know how you can continue to refute that.
That's your assumption.'usually'
Hello,
.... My question is this, has anyone seen a transformer not able to take additional loading like that? I don't believe they were increasing voltage to cause saturation. I've never seen it before, usually it just runs over temp....
And it's fine that it is.
An assumption nevertheless.it is an interpretation, mine and others
thanks for allowing me freedom of thought![]()
Any moderator!
How long is this "childness" to continue!!!
Phil Corso
Changing the title to infer that those posting were stupid can only be interpreted as offensive.We have chosen to let it run on here where it does not hurt anybody rather than in the original thread where the OP would be shaking his head sadly.
It rather surprises me that a respected mod would do that.
Water under the bridge.N.B. the only change I made to the title was to change 3X "your" to 3X "your'e".
The original title was set when the posts which started this thread were removed from their original thread as non-contributory or impolite. I do not know who did that.
You two may not have noticed that you were no longer posting in the original thread nor that the OP does not seem to be following this thread.
[Aside, in a stage whisper,: Anyone who disables PMs from the Mods and Admins should be prepared to be criticized and or chastised in an open post or be given infractions or other discipline without warning.]
And I still have the most amazing dog in the universe.......
He walked an old, disabled lady home today.
I can't work out how he just knows.
All of the above. And more.Highly intuitive as well as wicked smart?
Sheep dogs, more than most other breeds have been bred to understand and take direction from humans.
Experiments prove conclusively that dogs, unlike other canines, are good at reading human emotion and intent from facial and behavioral cues.
But we are straying off topic.
There's a topic?![]()
