jxofaltrds
Retired ESI
- Mike P. Columbus Ohio
- Creator
Now you are losing.
"They are both part of the potable water system and do not constitute two separate systems."
Says who? Site me, other than an opinion, a code that says that they are 'one'.
"I use the text found in the Report on Proposals for the electrical code when trying to learn something about the NEC. I sure don?t look in any other code to see what they allow."
So if the NEC say that your holes only have to be XXX"'s away from the face of lumber thats OK? What if it is a floor joist?
"Wouldn?t you say that the one comes first would carry the most weight?"
So if my post was first I would win?
No as in ALL code the more specific always wins.
"potable water system "
Is that in the NEC? The NEC says metal water piping. Period.
You are losing this battle.
"Plumbers are not allowed to remove any electrical connection at all just as an electrician is not allowed to remove any plumbing at all unless they hold a license in the prospective field. "
And this has to do with bonding how?
