What is your earthing system in France btw?
For homes, the SLT TT is mandatory
Best regards
Unlike mbrooke I could not possibly care any less at all about what other countries use or how they do things. i am not an electrician outside of my area.
Best regards![]()
It does not make them ignorant, it makes them get paid.
The type of fault that an AFCI is said to detect. A sparking/arcing type of fault.Thank you don_resqcapt19 for your reply
Could you tell me what you call "arc fault" please?
Thank you in advance,
Best regards,
ICC-
I'm unaware of GFP that address circuit overloads Mr IWire
~RJ~
And purpose and design.
A GFCI or GFP may be part of a combination unit as in a GFCI or GFP circuit breaker or they can be stand alone devices that only protect against line to ground faults and do nothing for line to line faults or simple circuit overloads.
Can I ask you why a person living in France cares one bit about what the NEC AFCI rules are?
What device does protect against circuit overloads?I'm unaware of GFP that address circuit overloads Mr IWire
~RJ~
Perhaps these, in the sense they are a single unit of GFP and OCPD?
Would you sell a homeowner one of these for $1000, and tell him/her they'd never have an electrical fire Mr Iwire?
~RJ~
There were lots of states that took a look at this issue...in some cases the legal advice was that the unit of government is on shaky legal ground when they pass a code that is less stringent than a national consensus standard....
From a legal standpoint, but it does not make it right. Everyone one of those folks have the power to ask questions and write to legislators. And it does not mean those who have power over laws should sit idle. Consider how many states, municipalities, ect have adopted the NEC without even questioning 210.12. Michigan and Indiana were the only ones that did in any detail. New Hamshire was looking into it, but I am not sure what side they took. ...
I still have no idea of what you are asking. An overload is one of the things that an overcurrent protective device detects.Perhaps semantical , but i would have stated circuit over current myself Don
~RJ~
It's the same here, we have a different classification for faults. We never speak about arc, because arcs are always consequence of defautls.
Never arcs like your vidéo, never.
And never false tripping with sensitive breakers, never.
The posts on this forum do not carry the weight of money and fear that the AFCI makers can put forth.
And you think the manufacturers will let that go over some rants on an Internet forum? Seriously, AFCIs are here to stay until the manufacturers come up with the next gizmo that is at least as profitable. You know the price will not come down.
The way IWire posed it, or i took it, was that GF incorporates overload protection
It, in of itself, does not....
Overload and GF protection are two separate distinctions incorporated (or not, as the case may be) into the same device
~RJ~
I was very clear what I would do. I will follow the code as required regardless of how I personally feel about it.
Compliance and complaint about any given electrical product are two separate issues Mr IWire.
I'd like to think most of us are compliant ,or make a good faith effort in our installs here , which is why we come here.
But you see, i like my trade ,and i'm cursed with scruples. I think you'll find there's many of my sort here, as well as the usual (if not high ratio) of FF/Sparks who have seen the forensic blame game first hand.
That said , i have a complaint , in fact i've had one for nearly 2 decades re; afci technology.
Fwiw, back then i was 'Mr. tin hat' ....
And yes, the Manufacturers are a phenomenally huge Goliath , but the evidence against them is mounting and our grass roots campaign has put substantial dents in their armor.
All litigant entities and journalist investigations aside, simple word of mouth is a powerful animal down in the 'trenches of the internets'
Ergo, I'll side with Mousieur Charles , the proverbial David of our trade
And one last thing, the least you could have done is used the right brand extinguisher to make the lamp out of.![]()
I stand corrected on that point.....
~RJ~
