- Illinois
- retired electrician
...I am sure they would like to hear it.
The
Thereally says it all...they don't want to hear anything that says they may have been wrong.
FYI - Their are 11 voting members on CMP 2 - Only 3 of them represent manufacturers of the devices. The other 8 are Inspector Association Members Reps, Home Builders Association Reps, UL , Intertek, Utility Companies, Municipal Inspectors, Electrician Associations like like IBEW and IEC and so on.Thereally says it all...they don't want to hear anything that says they may have been wrong.
That wink was not stating that....their is only a few manufacturers on that panel...the rest are industry advocates and so on.....so I am sure they will welcome your thoughts.
There have been any number of well substantiated proposals that were shot down by that panel. They have been sold a bill of goods, and they will never, no matter what is presented to them, reverse this rule.FYI - Their are 11 voting members on CMP 2 - Only 3 of them represent manufacturers of the devices. The other 8 are Inspector Association Members Reps, Home Builders Association Reps, UL , Intertek, Utility Companies, Municipal Inspectors, Electrician Associations like like IBEW and IEC and so on.
So you have 8 other CMP individuals who must drink from the TEA of lies.......I would think you could convince the majority with your factual data......give it a shot my friend. I am not on this specific panel but I would gladly step out of mine to witness the presentation.
I have never suggested this is a manufacturers issue...the panel was just sold a bill of goods by some very good salesmen.That wink was not stating that....their is only a few manufacturers on that panel...the rest are industry advocates and so on.....so I am sure they will welcome your thoughts.
UL's report titled "Evaluation of Run Length and Available Current on Breaker Ability to Mitigate Parallel Arcing Faults" strongly supports the idea that a lower magnetic trip would be better.I respect where you are coming from, but out of curiosity has the CMP ever studied IEC based codes (like BS7671) before implementing AFCIs? It seems other countries have a low cost solution (GFP + low magnetic trip) instead of expensive AFCIs for dealing with cable faults.
That is one of the issues with the code making process...the little guy can't really make a presentation to the panel. It would cost me a couple of thousand dollars to do that when you look at lost wages, travel, lodging and food.... I am not on this specific panel but I would gladly step out of mine to witness the presentation.
This photograph shows a small fire which began in a non-metallic sheathed (NM) cable thirteen years after it was installed inside a closed ceiling space. The cable was fed by a properly sized, 12X circuit breaker. It is not unusual for cables or power cords after being damaged to take years before their insulation finally breaks down enough to allow short-circuit current to begin flowing.
"Stick it to the consumer"......I think not. Granite counter has to be one of the most fire proof items you can have in a house. There should be a lot more of it. It's not an upgrade it is an investment in safety and piece of mind.I say you mislead the numbers......The fact is there are way more people out in the REAL world that support AFCI's than you lead on......that all of the "Select" group of individuals lead on. Rather than get involved and help make a good product better....you are no different than the Home Builders who cry about AFCI's only to stick it to the consumer for that $5,000 granite counter upgrade.
What AFCI's are designed to detect seems to change with each new batch that comes out in attempt to get rid of legitimate nuisance trips.Fact is......they have proven to work...read the CPSC reports on them...but I guess they are swayed by the Manufacturers also...right..... Are AFCI's perfect....nope....are GFCI's perfect...nope......but they can detect what they are designed to detect...not what they are not designed to detect.
Any of those TV's on a circuit fed by an AFCI?Seems to me I purchased a 55 inch TV 2 years ago...only to end up buying a 65 inch TV a year later.....and then a 70 inch just this year......why because technology evolves and the next best thing is always around the corner. Again are AFCI's prefect...nope...never said they were but in terms of improper use of cords and shotty wiring....it is simply one line of added defense in the game.....again we can agree to disagree but don't use your position to take pot shots at others opinions by saying they are lying.......other opinions that differ from yours are welcome I last checked.
BIG difference is the consumer doesn?t get stuck with them because they are not required, he gets to choose
Maybe it is time for CMP2 to own up to this mistake and remove AFCIs from the code.
Yes, I am sure Granite Counter Tops have saved alot of homes from eminent disaster.....let's thank the Stone Industry for that impressive life saving advancement:angel:
Do you guys really hear what you are saying....lol.....it's like you are all placing AFCI's in the same vein as UFO's....Alas....I think I told myself (on multiple occasions) that I am not the one to lead this fight FOR the AFCI industry.....they know about the debates here because I have told them about it.......Eaton Knows and Schneider Knows....and Siemens Knows and the experts are out there.....I will leave it to them to defend their products....I support AFCI's based on MY experience with them as a Master Electrician and Chief Electrical Inspector.......it only enhanced it when I became a NEMA REP because I could ask the questions to the sources and I agreed with the responses (Yes, I drink the same Tainted Tea you speak of)......BUT....I am also a code guy and if the code says use them I use them and gladly pass the cost on to my customer not because I can, it's because I believe they offer some merit and anything that might add safety to my family and my home I am putting in and promoting...
So you can support them or rebuke them.....I don't work for a company that makes them, I don't represent an association that promotes them....I just as a Master Electrician like many of you...believe in them. I accept their possible flaws but I also accept their ability to do what they say they can do...I also believe in the Bible as well.....so I have faith in BOTH being accurate.
Assuming these devices are what they are all cracked up to be, what assurance do we have that after they are 25-40 years old that they still protect the wiring that is likely starting to develop some of the problems they are supposed to protect us against?
An electrcian that lives and works in both Paris and Wisconsin. But I will conceded that is pretty thin.
But you just confirmed it.
My understanding is the RCDs are used in the main supply so that a trip takes out all the power not just a branch circuit. I find that unexceptable as I think most customers would.
I am also a code guy and if the code says use them I use them and gladly pass the cost on to my customer not because I can, it's because I believe they offer some merit.
I use the Arc Fault breakers and pass the cost on to the customer because I don't have any choice and the customer acccepts this cost because they don't have any choice.
I saw a house where they had a panel filled with Arc Fault breakers ( panel moved more than 6 ft). The code requires these Arc Fault breakers. But there were not even smoke detectors in the house or carbon monoxide detectors ( not required ).
Given the choice of where to spend some money I know where I would spend it. If they have a fire it may not be electrical and it probably won't be fire that kills them but smoke inhalation.
I?ve asked about testing GFCI?s on here before. If anyone was to suggest ?pressing the test button? as an acceptable test in the UK they would be laughed at.
