al hildenbrand
- Minnesota
- Electrical Contractor, Electrical Consultant, Electrical Engineer
Now if you had an amendment like Massachusetts's Rule 3, you could probably continue using your non-compliant "EGC". But that just shows that Massachusetts feels the same way I do, because they had to make an explicit rule to allow you to do that, since the NEC itself does not allow it.
As you can see, I'm in Minnesota. I don't have a comment, other than to respond to you points and analogies as you requested.
