wbalsam1 said:
Section 110.3(B) requires compliance with the installation and use instructions which are always included with products that are listed and labeled. In many areas, the code actually specifies the use of listed products. Other areas, the code requires products to be listed, labeled, etc. The safety standards whether amended or not, the installation codes and methods, whether amended or not, and the quality of installation and the quality of inspection all work together to produce an effective system. None of these components are exclusive of the other. A strong and close working relationship between or among all the parties, i.e., product standards development organizations, installation codes writing organizations, installers and inspectors, is paramount to the end use being safe. To make the argument that gas piping bonding requirements is reduced to an issue of pointing fingers for installation responsibility, is IMO, a gross distraction of the intent of the electrical standard for effective bonding. New standards can occur at any time. So can modifications to existing standards. Many standards come together to create the NEC. See Annex A, for example.
This is quite a thread. Reminds me of the old saying "A Camel is a horse designed by a committee."
good luck with this argument, i've tried it before(although not so eloquently!!)
to MD (an others)- i would ask.... you are making an argument based on the fact that "i don't know about it" when , in this case, you do. you also say the NEC does not cover it (it may or may not, i won't argue with you over that)
now the question- what will you do NOW that you DO KNOW about it????
i would submit that it is all of OUR (builder,inspector,contractor,electrician, sheetrocker,plumber,ect,ect,ect,ect,ect,)responsibility to build the SAFEST BUILDING POSSIBLE.
the reason i have a problem with anyone using the "it's not my job" argument is simple-
who is more at fault??? the installer (of ANY item, in ANY building) that makes an error and forgets or installs something incorrectly-or the person who sees it, and KNOWS IT'S WRONG,YET DOES NOTHING ABOUT IT????? everyone makes mistakes, but to see, and ignore is just wrong
if a sheetrocker sees a missing plate over a conductor or plumbing and does not replace it- i (personally) hold him more responsible than the installer who missed it. (code or no code!!!)
is it his "job"??? NO.
should he have corrected it? YES.
IMHO only....
