xptpcrewx
Power System Engineer
- Las Vegas, Nevada, USA
- Licensed Electrical Engineer, Licensed Electrical Contractor, Certified Master Electrician
You're missing the point. The objective is to know about these things before you start tearing into equipment and before you agree to the work."just" replace a couple of GFI's..... there are no five minute jobs,
Ok, you decide to just replace a couple of gfi's, you open the kitchen receptacles and they are on a 15 amp circ with the lights.... now what?
It seems to me the owner is relying on the contractor to provide their expertise and do what is required to do the job correctly (including define the scope and quote the job appropriately). What makes you think the owner only wants a panel upgrade with a failed inspection?The gfi's are NOT part of the panel change contract.
In Nevada, depending on the facts of the case, the contractors board would likely side with the owner and expect more from the licensed contractor. Hiding behind a contract you drafted is iffy at best especially when your expertise was called upon to begin with to represent the owner who rarely knows how any of this works. Think about how this would look if the owner was an elderly person or a person with a diagnosed physical or mental disability.
I'm definitely ranting now, so it would be good to hear from the OP to see what the real situation is.
