LJSMITH1
- Stratford, CT
That is one of the points I'm trying to make, so maybe we agree.
I think we do on some levels.
Another point would be the objective of the instructions. I have instructions for mounting a ceiling fan box that says to use a lone 2x4 as a brace. The idea is to provide adequate support. To me, I can also use a 2x6 or any brace that would give me equivalent or better support. In some cases, I don't think a simple 2x4 would be the best choice. Just an example of where it does not always make sense to follow the instructions "to the letter" and shows there is more than one way to install the device without damaging the device's performance..
Conversely, another variation could get you in trouble - using a 2"x2" or a 1"x2" because that was what was laying around on the jobsite. I agree with what you are saying, but the logic can cut both ways. You may think the guy that used those smaller pieces of lumber is an idiot, but to the guy who did it, it was a good decision - until the fan drops on someone's head...
The point being is that there is no way for UL or the manufacturer to test/evaluate/analyze every iteration of possible installs for a given product and application. So, they just go with the most common or critical. Maybe in your example, the instructions should read "use a 2"x4" minimum"...
And that can be where the real pain in the neck happens.
At times, I am sure that this is the case.
