try to see rattus's viewpoint
Rick, as for the current probe, it is just a shunt. I can give you a link to some websites where you buy varying sizes if you would like one.
Putting the words "current probe" in quotes was a shorter description.
First, I am not arguing that a single voltage/current direction is not the best way to analyze the circuit. Actually, for the circuit given, I think it is the best way because, as Jim pointed out, it simplifies the analysis.
But given that rattus (or someone) proposed using the neutral point as a reference, you now have what "scopes out" to be a phase shift.
When rattus was describing V1 & V2 as being "out of phase" across the neutral, that is fine with me, let's help him describe it. Whether we like it or not, let's try to look at it from his standpoint. We are not promoting "violating" any laws, just a way to describe what he wants.
Getting away from the fact that the original simple circuit was not drawn this way, it seems apparant that what rattus wanted was the following: Given that the two voltages shown are identical and in series. It appears rattus wants to call the two voltages across the neutral as "out of phase" across the neutral. This is what you would see on an oscope with the neutral as the common point. Still fine with me, let's help him do that without "violating" any laws.
There seemed to be agreement that we were going to "allow" the voltage across the neutral to be called a "phase shift" for the sake of rattus's analysis. The problem than was that I believe it was alluded to that if you allow this, then the voltages would be "out of phase" with their currents.
This absolutely can not be in the resistor circuit. We really would be "violating" some laws.
My thought was that if you have a concept that allows the "voltage crossing the neutral" to be called a "phase shift" then, by the laws of physics, you have to have a
reciprocal concept for the current. If the phase of the voltage "shifts" then so must the phase of the current. Using the "current probe" was a way to show this in the physical world.
If you can observe the "phase shift" on an oscope for the voltage, and if you found a way to scope the current, you would HAVE to be able to observe the same "phase shift" on the current. Actually we do have a way to observe the current wave on the oscope, and it is by using a measuring shunt or "current probe".
The concept of a simultaneous phase shift of voltage and current when you cross the neutral allows rattus to continue using the convention he wants and we can not accuse him of "violating" any laws.
The concept of the voltage shift was easy for everyone to see in the physical world because the oscope or meter is the obvious example. The north pole, "coming vs going", etc was my attempt at trying to give a physical world example of the current shift. It would seem I have failed miserably so far.
