resistivity ohm cm
sea water 25
tap water 1000 , well water is lower
assume a length of 10" or 25 cm
coss sect 10x10 or 100 sq in or 650 sq cm
R = 1000 x 25/650 = 38 Ohm
body wet say 800 ohm
120/838 = 140 mA, death
now, large tank
length 20" front to back, 50 cm sq
cross sectional gradient path 36 x 20 = 4600 cm sq
R = 1000 x 50/4600 = 11 ohm
the larger to pool the worse
a lobster tank and many aquariums have salt water
R = 25 x 25/560 = 1 Ohm
the bigger the tank the lower the R
contrary to youtube water is a good conductor
guess that is a reason for IP ratings and wp boxes
what you don't know will kill others
sea water 25
now, large tank
