You think of water = GFCI. There is more to it, perhaps you do not grasp it.
it is not I who lack understanding :lol:
all 20 code sections relate to water/moisture
ohm m
pool L = 10, coss section 10 x 2 = 20
pool
R = 0.4 x 10/20 = 0.2 ohm
drinking
20 to 2000
thin puddle
L = 1 mm = 0.001 m
A = 1/4 x 1/4 = 1/2 sq m
R = 20 x 0.001/0.5 = 0.04 Ohm
R = 2000 x 0.001/0.5 = 4 Ohm
all <<<< body Z
you know not of what you speak
Swimming pool water[j] 3.33×10−1to 4.00×10−1 0.25 to 0.30 [32] Drinking water[k] 2.00×101to 2.00×103 5.00×10−4to
The first residual current connection circuit-breakers were manufactured in
1954.
Real number and real concepts, again taken out of context in relation to the discussion at hand.
You are claiming water will trip an OCPD, even a GFCI all the time- but as your numbers show water and electrode surface area and distance play a role.
And concrete among others- why does an unfinished basement need GFCI but not a finished one?
All these areas are places where conditions lower body contact resistance and/or (body) fault path be it concrete, dirt, moisture, grounded object likely to be in reach, ect. In this cases an energized object is very likely to be lethal.
BTW, differential technology existed before Dalziel. Technically he did not invent the device that trips on such a scheme:
Bottom of page 6:
http://www.studiecd.dk/cahiers_techn...evolutions.pdf
you said tap or pool water has very high R and likely not trip a gfci or mccb
I say and PROVE it will with REAL world data and simple computation
they are not MY numbers!!! lol
R = p x L/A are everyones
OBVIOUSLY L and A 'play a role', are you stoned!?!?
I see the light of Jumpers bow out post
I feel a little bad like I'm teasing a kitten lol
MOISTURE!!!!!
MOISTURE!!!!
wrong
he invented and patented it
All the videos I posted already did. Even with Clive's salt water electrodes, spaced about 1/4 of an inch apart, about 6 inches long- and on 240- no breaker tripped.
Yes I know- but taken out of context and not the whole picture.
Jumper may automatically take your views without discrimination, but I am not like that.
which lowers skin conductivity![]()
Then why does my paper say otherwise?
every experiment can be rigged
you do not get it
Jumper does not take MY position, he comprehends the basics, which you do not
really?!?!? it is in series, skin p stays the same
contact R decreases
because it is wrong
Yahhh, all 5 You Tube vids are rigged. :roll::roll:
You spit out numbers which on a few occasions do not tell the whole story as in this case.
In simple terms we can say skin resistance at the point of contact is lower.
A paper by Schneider wrong?
yes, Ohm's law is rigged lol
you can't read the equations, hence you miss the whole story
in simple terms, but incorrect terms
inaccurate
OSHA
How does water affect the flow of electricity?
Pure water is a poor conductor. But small amounts of impurities in water like salt, acid, solvents, or other materials can turn water itself and substances that generally act as insulators into conductors or better conductors.
Dry wood, for example, generally slows or stops the flow of electricity.
But when saturated with water, wood turns into a conductor. This means that anyone working with electricity in a damp or wet environment needs to exercise extra caution to prevent electrical hazards.
anything can be taken out of context or misapplied.
Elaborate. Educate me on what that paper is saying.
[/B]Yes, of course, but usually not enough to trip a breaker under the conditions were have in mind in this thread.
[/B]Does it? I wouldn't use it as a hot stick.
Yes, again, conditions that lower skin contact R.
So.......must GFCI's be used near a lobster tank, or not?
ohm m
pool
drinking
20 to 2000
thin puddle
L = 1 mm = 0.001 m
all <<<< body Z
