- Massachusetts
As much as I'm trying to stay away from what looks like classic "trolling" on your part -
It is classic trolling without a doubt.
Trolling means deceiving.If you think I posted false information with an intention to deceive,you may list them for all others to see.It is classic trolling without a doubt.
Or it might have improved before it got to that parlous state of affairs.I would have been beaten senseless, grammar and spelling has always been a weak point for me.
GPA? 4.0? Remember I'm a :? Brit.College composition and English courses wrecked my GPA. I blew a 4.0. It happens.
Thank you kindly.Back on topic: What meter are you using? Your readings are impressive.
No.Are UK residential customers charged for PF?
I think the great majority are typically with a single fairly fairly large 11kV/400V (Dyn) transformer feeding a residential area.Are all UK residences derived from a 3 phase source?
Thank you kindly.
I usually use a digital storage oscilloscope.
I routinely carry around a Tektronix TDS 220 with an RS232 serial port so that I can download waveforms directly to a PC - provided the PC has a serial port of course.
More commonly for the measurements of the sort I've given in this thread I use this
My simulation software has this. It is the same as I used in classes, but ours were 2 channel only.
I wouldn't mind having one for real life applications.
The above is based on the assumption that the motor current will increase at reduced voltage. That is by no means a certainty.If h.p,power factor,and efficiency of the pump motor are known,it is possible to calculate the increased current X at reduced voltage without the capacitor and the reduced current Y at increased voltage with the capacitor across the terminals of the motor.Once the values X and Y are known,further calculations can be made to ascertain the saving that could be achieved.
I want to tell you one incident from history.The famous scientist Sir Issac Newton was wrongly blamed for his interest in Alchemy.The real intention of Newton was to discover whether there were any scientific principles behind the quest of alchemists for gold that could be beneficial to the humanity as a whole.The same is going on here.All I can say is WOWWWWWWWWWWWWWWW!
But to throw my two cents in, if it walks like a duck, and quacks like a duck, it is a duck.
Don't have any of those tests you guys have, but the moment I heard about these "energy saving devices" it quacked like a duck to me. I mean scam.
A pump motor behaves that way.A sample in an indirect way is given atThe above is based on the assumption that the motor current will increase at reduced voltage. That is by no means a certainty.
I am working on a set of notes on Electrical Energy Measurement, Conservation, & Methods to Reduce Your Electric Bill. To try to illustrate to readers that power factor correction black boxes are probably useless to the average residential customer I have run the experiment that follows. This is based on the type of demonstration shown in the fraudulent advertisements.
It is probably correct to say that virtually no residential customer in the US pays a penalty for poor power factor. Thus, power factor correction is of no value to the customer.
Yes.The current drops with drop in voltage across the pump motor,if the water output of the pump also drops at the same time.This is an abnormal condition not to be taken into account for the present study.No, a pump motor may behave that way but not always.
Your study is proven one beyond doubt.My endeavor is to see whether any thing can be salvaged from that scam,just as the great Newton tried to do for Alchemy.111115-2117 EDT
T.M.Haja Sahib:
The first two paragraphs of my post #1 are:
These two paragraphs set the stage for what I am trying to illustrate to the average homeowner interested in trying to reduce their electric bill, reduce energy consumption, and "carbon footprint".
Since you may not be familiar with the fraudulent ads, and what they describe may be the reason you drifted to unrelated points. All of these ads describe installation of the power factor correction box at the service entrance main circuit breaker panel. I believe that in most homes this means only a few feet of wire from the meter to the panel. In my case it is probably 6 to 8 feet of 0000 copper.
I do thank you for reminding me of the low dissipation factor of polypropylene. At the time I ran the experiment I had not actually measured the dissipation factor of the capacitors I used. Since then I have made the measurement with a General Radio 1650-A bridge at 1 kHz. The 30 ufd capacitors measure about 0.002 for D and the 12.5 ufd about 0.02. Thus, the capacitor power dissipation should not be as large as I measured. This implies there are inaccuracies in the instrumentation I am using that prevent high accuracy in the result. But the accuracy is sufficiently good to dispute the claims of the advertisers.
You need to do an Internet Google search for Power Saver 1200 and then look at some of the sales video material to get an understanding of my goal. No way can any homeowner reduce their energy consumption by the implied 25%, or even the guaranteed 6%. One place told me they use two 40 ufd capacitors, one for each side of neutral. XC is about 66 ohms at 60 Hz, and at 120 V is about 1.8 A. This current always flows whether inductive loads are present or not. But this does nothing for I2*R losses in the house.
I need to re-describe the results of my experiment to indicate that within the accuracy of my measuring equipment there is no energy saving for the homeowner by the use of one of these power factor correcting devices at the main panel.
To see a typical day of my load power see photo P26 at
http://beta-a2.com/EE-photos.html
http://www.powersines.com/apage/83528.php
Fixed frequency cage motors are typical of this application.Yes.The current drops with drop in voltage across the pump motor,if the water output of the pump also drops at the same time.This is an abnormal condition not to be taken into account for the present study.
Do you know pump affinity laws? Have you checked your statement with them?If the motor is underloaded, as most centrifugal pump motors would be, then reducing the voltage will also reduce the current without a reduction in water flow.
Please look again at tables.The current in save mode is less but the voltage more;the current in the bypass mode is more but the voltage is less.This is what I am asserting.If you actually read the article you will see that it resoundingly contradicts your assertion.
Look at the tables and you will see that the current in save mode is significantly reduced than in bypass.
And look at the title:
"Reduced Motor Voltage to Mud Pump Motor Load."
