Electric-Light
I am not sure how they did away with the electronics, but it works great. I having some ceiling lights with mixed incandescent and LED bulbs. You can not tell the difference between the old and the new when it on or off.
Here a link to them at HD:
http://www.homedepot.com/p/EcoSmart-60W-Equivalent-Soft-White-B11-Filament-E12-Energy-Star-and-Dimmable-LED-Light-Bulb-3-Pack-B1160WFILE123P/300657417
LEDs require a ballast. A keychain light that direct drives a single element emitter from two 3v coin cells in series is ballasted by the high internal resistance of the coin cells. The LED element will fry quickly if it was connected to a low impedance source like a 6v NiCd pack.
When you wave your hand in front of it or flip through book pages, do you see this effect?
Every AC utility driven LED products without an electrolytic (or expensive tantalum or absurd quantity of ceramic caps) caps suffer from this due to the lack of glow persistence of the phosphor blend used in blue LED excitable fluorescent material. The after glow that lasts for several seconds on some LED bulbs is not because of phosphors, but the LEDs being kept up by how and amount of capacitor in the ballast.
Each LED filament is a stack of LED elements wrapped in a phosphor impregnated sleeve. The capacity of stand still air is limited. They are gas cooled to allow increased power input. The filaments are put in a glass bulb like a normal light bulb but filled with helium which has about 6x the thermal conductivity of air.
LEDs must be ballasted but does not have to be a transistorized electronic ballast. it can be just a series resistor or a capacitor on its own or with a bridge rectifier. If it's just a resistor, the filaments are wired back to back internally or externally and they alternate between two sets each half cycle and pass on the extreme flicker. If there is minimal flicker, there is a capacitor inside the base. The resistor could also be hidden somewhere within the gas cooled bulb.
You WILL find the ballast if you rip the base off and carefully trace all path leading to the LED filaments. Usually, those that use full size (medium base) sockets have a capacitor to flywheel the LED current to prevent inferior light quality caused by flickering.
A passively ballasted LED lighting without a switch mode transistorized LED ballast is not expected to spaz blink when it fails, but it will produce light that is inferior to incandescent, fluorescent or HID in some way, because the light will have a percent flicker of 100% and a flicker index of about 0.5 (out of 0 to 1.0).
