Excellent.My '96 Honda Nighthawk 750 engine is rated at 56kW.
The Jag in my avatar was 224 kW.
I'm sure the 750 is most likely 750 cubic centimeter of displacement as well.My '96 Honda Nighthawk 750 engine is rated at 56kW.
Most US engineers are bi-dimensional, I even think in metric in other than mechanical construction.
Perhaps we should all go back to Megalithic yards.
Wonder what electrical units would look like in Megalithic terms ? Other than any precursors of Bagdad battery, no archeological artifacts though
I'm pretty sure the French horsepower is the metric horsepower, 75 kilogram-meters per second.Don't forget French Horsepower!
Phil Corso
(which is actually a measure of impulse, not power, because the kilogram isn't a measure of force)
I'm also pretty sure the French don't use it any more.
Probably so it would be approximately the same as the British horsepower. (736 vs. 746 watts)My question is why 75 and not 100? ...
Could'a been, but wasn't. The kilogram-force per square meter [sic] was also popular in a bygone era.... Newton is a unit of force that could be used instead of a unit of mass.
Because that's what it works out to be.My question is why 75 and not 100?
I thought a pound of beef at Asda was 400 grams..they are shorting me? Hmmmm75 because it was a round number which gave a result that was close to the 'imperial' unit.
In a 1 g field, lifting 75 kg 1 m per s is about 736W.
Sort of like 500g being used as a 'pound' in areas where metric is used but there is a tradition of using pounds.
-Jon
Enlighten us, Dr. Phil!Now, why do you think it's use here, is spotty at best!
Phil Corso
I think he means it is not used consistently for all measurements,Enlighten us, Dr. Phil!![]()
But we do use many items from international treaties without realizing it. So many of the symbols we use in electronics are international symbols. Most of our road signs are using international symbols, so much so that I keep wondering will I return to the USA and see the round speed limit signs on the posts...lol... even the stop lines I got used to in many states are used in the UK and Europe.For those of you who don't know...
We, the USA, signed the world treaty to accept and use the International System of Units (SI) in 1866! Now, why do you think it's use here, is spotty at best!
Phil Corso
One advantage of legal marijuana is having to know the metric system...
I agree metric units are much easier to work with, where I work all our lab work is metric, as most places are.
But with metric its all or nothing, which is why our previous attempts in the US have failed.
English Oxford Dictionary.
They're all interrelated, but not the way you seem to think.
The old metric system (c.1700s) was based on the boiling & freezing points and density of water, the distance from the equator to the North Pole, and so forth. But that's long obsolete.
In the centuries since then, we've discovered that the water's characteristics aren't constant - density varies with temperature and boiling & freezing points vary with pressure. So it became necessary to redefine the fundamental units in order to be able to make precise measurements that are the same everywhere. The meter was redefined in terms of wavelengths of cesium light, the kilogram was defined in terms of a pure silicon sphere and so forth. Those harmonizations & redefinitions mark the transition from the old metric system to the current SI system.
Yes, in the CGS system.Technically though, aren't all the units from that system interrelated? One gram of water is equal to 1 cubic centimeter of water?
Some units you already use are SI. There is, for example, there is no Imperial equivalent of the Amp or Volt.Really it doesn't matter what we call it, I am with you. I would gladly convert to SI across the board. It would be difficult at first, but the payoff is huge.
Système international.
