Units of measurement
RichB
Tacoma, Wa
Electrician/Electrical Inspector
Most US engineers are bi-dimensional, I even think in metric in other than mechanical construction.
Perhaps we should all go back to Megalithic yards.
Wonder what electrical units would look like in Megalithic terms ? Other than any precursors of Bagdad battery, no archeological artifacts though
Is that like being "bi-sackual" at the store?? Paper or plastic ?:roll::?:angel:
kwired
Electron manager
NE Nebraska
I'm pretty sure the French horsepower is the metric horsepower, 75 kilogram-meters per second.
(which is actually a measure of impulse, not power, because the kilogram isn't a measure of force)
I'm also pretty sure the French don't use it any more.
My question is why 75 and not 100?
Newton is a unit of force that could be used instead of a unit of mass.
winnie
Springfield, MA, USA
Electric motor research
75 because it was a round number which gave a result that was close to the 'imperial' unit.
In a 1 g field, lifting 75 kg 1 m per s is about 736W.
Sort of like 500g being used as a 'pound' in areas where metric is used but there is a tradition of using pounds.
-Jon
Adamjamma
-Jon
I thought a pound of beef at Asda was 400 grams..they are shorting me? Hmmmm
Phil Corso
For those of you who don't know...
We, the USA, signed the world treaty to accept and use the International System of Units (SI) in 1866! Now, why do you think it's use here, is spotty at best!
Phil Corso
Adamjamma
Phil Corso
But we do use many items from international treaties without realizing it. So many of the symbols we use in electronics are international symbols. Most of our road signs are using international symbols, so much so that I keep wondering will I return to the USA and see the round speed limit signs on the posts...lol... even the stop lines I got used to in many states are used in the UK and Europe.
Strathead
Ocala, Florida, USA
Electrician/Estimator/Project Manager/Superintendent
One advantage of legal marijuana is having to know the metric system...
I agree metric units are much easier to work with, where I work all our lab work is metric, as most places are.
But with metric its all or nothing, which is why our previous attempts in the US have failed.
That is funny I don't care who you are! I must admit that for dry weight that is why I have a full grasp of grams.
Strathead
Ocala, Florida, USA
English Oxford Dictionary.
Technically though, aren't all the units from that system interrelated? One gram of water is equal to 1 cubic centimeter of water? Really it doesn't matter what we call it, I am with you. I would gladly convert to SI across the board. It would be difficult at first, but the payoff is huge.
drcampbell
The Motor City, Michigan USA
Registered Professional Engineer
They're all interrelated, but not the way you seem to think.
The old metric system (c.1700s) was based on the boiling & freezing points and density of water, the distance from the equator to the North Pole, and so forth. But that's long obsolete.
In the centuries since then, we've discovered that the water's characteristics aren't constant - density varies with temperature and boiling & freezing points vary with pressure. So it became necessary to redefine the fundamental units in order to be able to make precise measurements that are the same everywhere. The meter was redefined in terms of wavelengths of cesium light, the kilogram was defined in terms of a pure silicon sphere and so forth. Those harmonizations & redefinitions mark the transition from the old metric system to the current SI system.
Carultch
Massachusetts
The kilogram is still defined by the international prototype platinum-iridium cylinder known as "Le Grande K". The silicon sphere from the Avogadro project is one of the two proposed alternatives that could redefine it. The other alternative is fixing Planck's constant as it relates to an experiment known as the Kibble balance, and this is the solution that is most likely going to define the new kilogram. It has to do with whether the uncertainty of the new method is an improvement over the existing uncertainty in Le Grande K, as we know from comparing it to the sister kilograms stored in similar conditions.
The fundamental advantage of the new methods, is that its definition would be independent of any individual object in particular. Just as the international prototype meter stick was replaced with the speed of light in free space and the definition of the second in the Cesium atomic clock.
Besoeker
UK
Yes, in the CGS system.
Some units you already use are SI. There is, for example, there is no Imperial equivalent of the Amp or Volt.
For others like the pound and the inch, there are readily available conversion tools if you don't remember the factors. It isn't really very difficult.
One of the obstacles to changing the systems used in the US is cost I suppose. You have say, a motor with a 2" drive shaft. To accommodate that, you need bearings that fit which won't be in SI units. That's true for old equipment here (UK) and I've often come across motors that were built in the 1950s and still in service.
winnie
The US currently uses SI as the actual basis of its system of measure, so that any changes in the definition of the meter are reflected as a change in the definition of the inch.
The inch is _defined_ as 2.54cm, _exactly_.
-Jon
