I just happened to have an old receptacle laying here on my bench. I didn't bother to try and cut it but I did pry it apart!
I see nothing in there that the screw (cover plate) would bridge the 2 halves.
However, there is a copper/brass piece that bridges the grounding pin from one half to the other. I'm assuming it is just to assure a tight ground connection as the ends are turned up at each ground hole, and would make a "spring" type clamp on the grounding pin.
This couldn't bridge the halves as it isn't long enough. It looks like it could cause a short though if it wasn't just right.
