Cold Fusion
- way north
No, not wasted. It is just sent back to the generator. The part that is wasted is the losses in the transmission of the .293W, shuttling it from the gen to the load and banc to the gen. The .293 is still available to use again, but the extra power it took to get it out and back are gone.
cf
You are right. The system is ot a finely tuned oscillator. However, the reactive power shuttles back and forth exactly as I outlined.You're making it sound like the system on the whole is a finely tuned RCL oscillator. It is not. You'd have to have some major PFC caps hiding [and connected] somewhere.![]()
Let's reduce the system to one generator, one transmission line, one motor.
Looking at the motor first:
Real power is either coming out the motor shaft, given off as heat in the windings, or windage and friction. In addition, the motor requires reactive power for excitation. That is stored in the stator mag field for part of the cycle and given up in other parts of the cycle.
Now lets look at the generator:
The generator driver must put out enough torque/rpm to the gen shaft to match the real power the motor is using/putting out. As you have said, that power is sent to the motor as current in-phase with the voltage. However, in order to supply the reactive power, the generator is over-excited, which makes it produce vars. Again as has been discussed, this reactive power is sent to the motor as current lagging the voltage.
That reactive power is shuttled - gen the motor and back - as the motor mag field builds and collapses. This power is not lost, the generator produces it and takes it back twice a cycle.
Now lets look at the transmission line and to a certain extent the gen and motor I^2R losses. The gen has to send the current it takes for the real power - no way out of that. So any transmission/motor/gen I^2R losses associated with that current are tough luck - have to have it.
The reactive current also produces I^2R losses. So this reactive current that is not producing power, requires real power from the gen/driver to make up for the losses.
So, no "finely tuned RCL oscillator" or "major PFC caps hiding". Just the way the laws of God and physics work out.
cf
